ONEX #54 Web Site
Date:  1-3-2012
Number of Hours:  5.00
Manual Reference:  W06-01
Brief Description:  Left flap assy
Completed W06-07 L/R flap drive assy's.
Cut left flap skin, W06-08L, and cut flap drive notch. Pilot drilled rib holes in the skin. Through drilled skin holes into flap drive rib and clecoed rib in place.
Pilot drilled hinge holes using the outboard spar spacer, W10-02, as a hole spacing guide.
Started to install the ouboard flap rib, W06-02, but found the rib flange would face outboard but the print suggests the flange should face inboard. See image 2. Will need to contact Sonex before I drill the outboard rib holes. Other similar assemblies have the flange inboard.
Left flap drive assy installed
Right rib in left flap. Left rib above.
